Dave Looman
Or perhaps you could make an assumption like the pressure on the plug would drop off after the plug traveled 1 inch.  Perhaps this could be an upper bound solution.  Then you could calculate the velocity at 1 inch of travel under full pressure and say it was an upper bound.  Applying this initial velocity in an impact analysis would at least give you a data point.
