The axis of the Rotating Force should coincide with or be parallel to one of the Global Coordinate (X, Y, or Z) axes.
You don't show a Global Axis Triad in your image. If the geometry does not have the axis of rotation parallel with a Global Coordinate axis, open the geometry in SpaceClaim and use the Move tool to orient the axis of rotation to be parallel with a global axis.
