Displacement Constraint: This constraint is applied at opposite face of Force (Uy=0) on solid body. Solver messages as under-constraint. If added this constraint in orthogonal direction (Ux=0) then works but this seems wrong. Because, adding additional constraint will neglect the poison effect. This problem is also in Friction-less and in Compression only support. Please, help to solve thisĀ problem.
