May 2, 2023 at 8:29 am
Hello Claudio,
so I tried to solve the model again with the command but I still get the out of core warning.
Yes, the model is linear elastic and only has small deformations.
I built the block with approximately the same amount of nodes and it is solved in core easily.
I noticed something else. Shouldn't have the bolt pretension and the working load (in the results of the bolt pretension) the same value if there's no working load?
Because this is not the case with this model if I use a finder mesh.
Thank you for your answer!
Tim
