I am assuming by "cold joint" you mean the interface between two bodies of concrete that have different material properties caused by poring and curing at different times?
If so, I would recommend a conventional bonded contact pair that is associate with a Cohesive Zone Material (CZM) model, so that the bond at this interface has a limit in tension and shear.
