May 2, 2023 at 1:52 pm
Hi Aniket, yes, the material is the same for all the skids and tubulars, it's Aluminum Alloy 7075. Just some info: in order to obtain a proper mesh, I had split the landing gear in 8 parts (2 skids and 6 tubulars) and after that I connected all the bodies with the default connections. By the way here are the remote displacements: in Pic A and B you can see the RDs for the first configuration (the asymmetrical one with low stress values); in Pic C and D you can see the RDs for the second configuration(the symmertical one with high stress values).
I have also created a remote displacement for the upper tubulars and promoted it in order to attach the remote mass :
And thank you for the quick answer.
