Colleagues, I did it. I measured the time of flight of a 1 mm plate under pressure and used it as the initial speed:
Speed 9291 mm/s
Here's what happened at that speed:
Max stress 436 MPa, material tensile strength 450 MPa. This means that the part severely damaged the shield, but did not break through it. Everything is fine?
