Bill Bulat
The APDL commands below are from an input file that defines an elliptical pressure patch that acts on the top face of a block and is then incrementally relocated along the x direction. Try copying them into a text file, then read that text file into MAPDL with the /INPUT command. I hope this helps you get started. Mind you, it looks like I created this back in 2017 and I haven't tested it to see if it still works, but my hunch is that it does.
Best,
Bill
finish
/clear
/sys,del file*.png
/vup,1,z ! VIEW SETTINGS. SPECIFIES GLOBAL CARTESIAN
! COORDINATE SYSTEM REFERENCE ORIENTATION.
! THIRD FIELD DEFINES Z VERTICAL UPWARD,
! Y HORIZONAL TO THE RIGHT, X OUT OF THE SCREEN
! YOU SHOULD USE A VIEW OTHER THAN THE /VIEW
! DEFAULT OF (0,0,1).
/view,1,1,3,1 ! DEFINES VIEWING DIRECTION FOR THE DISPLAY
/vscale,1,2.5 ! SCALES THE LENGTH OF DISPLAYED VECTORS
C***************
C*** PARAMETERS
C***************
r_ellipse=1 ! ELLIPTICAL BOUNDARY (MAJOR) RADIUS 101717
!r_ellipse=0.4 ! ELLIPTICAL BOUNDARY (MAJOR) RADIUS 102017
a=1.5 ! BLOCK EDGE LENGTH
t=0.2 ! BLOCK THICKNESS
ratio=0.5 ! ELLIPTICAL RATIO OF MINOR & MAJOR DIAMETERS 101717
!ratio=0.75 ! ELLIPTICAL RATIO OF MINOR & MAJOR DIAMETERS 102017
esz=a/25 ! MESH SIZE 101717 (RESULTED IN 392 CONTACT ELEMENTS)
!esz=a/37 ! MESH SIZE 102017 (RESULTED IN 200 CONTACT ELEMENTS?)
pmax=100 ! MAX PRESSURE AT MIDDLE OF ELLIPTICAL CONTACT PATCH 101717
!pmax=40000 ! MAX PRESSURE AT MIDDLE OF ELLIPTICAL CONTACT PATCH 102017
!*dim,ellip_coor_num,array,392,2,1 ! DIMENSION ARRAY TO CHECK COORDINATES
! AND ELEMENT NUMBERS 101717
C**********
C*** MODEL
C**********
/prep7
wpcsys,-1,0 ! DEFINES WORKING PLANE LOCATION AND ORIENTATION
! BASED ON AN EXISTING COORDINATE SYSTEM.IF 2ND FIELD
! (WINDOW NUMBER) IS NEGATIVE, THE VIEWING DIRECTION
! WILL NOT BE MODIFIED. 3RD FIELD IS COORDINATE SYSTEM NUMBER.
cswpla,11,1,ratio ! DEFINES / CREATES A LOCAL ELLIPTICAL COORDINATE
! SYSTEM AT THE ORIGIN OF THE WORKING PLANE.
blocK,-a,a,-a,a,,-t ! CREATES BLOCK VOLUME BASED ON WORKING PLANE COORDINATES.
et,1,185 ! MESH IT WITH SOME ELEMENTS
esize,esz
vmesh,all ! GENERATED NODES AND VOLUME ELEMENTS W/I VOLUMES.
et,2,154 ! CREATE SURFACE EFFECT ELEMENTS ON ENTIRE z=0 SURFACE
nsel,s,loc,z
type,2
esurf
alls
/shr,0.05 ! "SHRINK" ELEMENTS SLIGHTLY TO SEE SURF154s
/ann,dele
/tla,-0.25,0.90,Plate with SURF154 on Entire Surface
eplot ! PLOT ELEMENTS TO CHECK
/sho,png $eplo $/sho,close $/wait,1.5 ! HARD COPY OF SAME (IMAGE FILE)
/shr ! TURN OFF SHRINK
/wait,2
C*******************************************************************
C*** CREATE MACRO TO DEFINE ELLIPTICAL LOAD @ X LOCATION (ARG1)
C*** MACRO NAME: mvng_elptcl_prs,mac
C*** ARGUMENTS:
C*** ARG1: X COORDINATE OF CENTER OF ELLIPTICAL PRESSURE DISTRIBUTION
*cre,mvng_elptcl_prs,mac
wpcs,-1,0 ! WP @ GLOBAL ORIGIN
wpof,arg1 ! OFFSET WP ALONG ITS X AXIS (SPECIFIED BY ARGUMENT ARG1)
cswp,11,1,ratio ! DEFINE ELLIPTICAL COORDINATE SYSTEM @ WP ORIGIN
esel,s,ename,,154 ! SELECT SURFACE EFFECT ELEMENTS
nsle ! AND THEIR NODES
sfed,all,,pres ! DELETE PREEXISTING PRESSURE LOADS IF ANY
nsel,r,loc,x,0,r_ellipse ! RESELECT NODES WITHIN ELLIPTICAL BOUNDARY
esln,r,1 ! RESELECT SURF154s HAVING ALL THEIR NODES SELECTED
*get,nelems,elem,,count ! nelems = # OF SELECTED SURF154 ELEMENTS
elm=0 ! INITIALIZE ELEMENT NUMBER
*do,i,1,nelems ! LOOP OVER ELEMENTS
 elm=elnext(elm) ! elm = NEXT HIGHEST ELEMENT NUMBER ABOVE WHAT elm WAS PREVIOUSLY
 *get,r_csys11,elem,elm,cent,x ! GET ELEMENT elm's "ELLIPTICAL" COORDINATE
 sfe,elm,,pres,,pmax*(1-(r_csys11/r_ellipse)**2) ! APPLY PRESSURE TO ELEMENT elm
*enddo ! END DO LOOP
alls ! SELECT ENTIRE MODEL BEFORE PROCEEDING
*end ! END MACRO CREATION
/psf,pres,,2 ! SHOW PRESSURES AS ARROWS
*do,j,0,0.4,0.1 ! LOOP OVER X COORDINATE OF ELLIPTICAL PRESSURE DISTRIBUTION
 /ann,dele ! NEW ANIMATION FOR UPCOMING PLOT
 /tla,-0.25,0.90,elliptical pressure load centered at x = %j%
 mvng_elptcl_prs,j ! INVOKE MACRO (LOOP VARIABLE j PASSED TO MACRO TO LOCATE ELLIPTICAL PRESSURE DISTRIBUTION)
 eplo ! PLOT ELEMENTS w/PRESSURE ARROWS SHOWN
