Federico Alzamora Previtali
"No perturbations" would be suitable if the level of turbulence at your inlet is negligible compared to the rest of the flow. In this case, the velocity fluctuations at the inlet are neglected, creating a "flat" turbulent profile.
LES models require realistic inlet conditions. If the turbulence at your inlet is important, I imagine this would impact your solution.
