mkhademi
Hi Federico,
I tried once with the two hyphens, but did not work again. I did the simulations through GUI once. That is why I am using --resume=1. I will setup the simulation again on the GUI without doing the smulations to try again on the Batch mode with the simplest conditions. Meanwhile, can you please write the steps needed to arrange the simulation on Windows with a Batch mode. Maybe I have missed something. For example, Rocky.exe is the only file that must be added to the path? Thank you.
