Guilin Sun
A1: the bandwidth would be from electro-optic property of the device, but by photon lifetime.
A2: This is a large topic as so many parameters need to be set. ldf file can provide certain parameters, such as mode properties. Others will need to input either manually or using script.
You can import as much data as you can in the ldf file.
