kedi
Hello GL,
Thanks so much for your response! For the aforementioned simulation, I only had one task, which was running the setup as shown in the pictures in my post.
  1. Do you mean I can see a significantly improved performance when I have more than variations defined, i.e., sweep one of the parameter variables in the Optimization?
  2. Could you elaborate on what you meant by "if you have enough HPC license?" Is there any way I can check it?
