> Still, I don't know how to compare the speed.
at least for this question, typically what we do is to test the scaling performance. You can simply try running a case on 1 node and N nodes. If N nodes is N times faster. Everything is fine. But be sure to use a relatively large mesh (like more then 3 million cells).
