majam
Close to the saturation if I do not decrease URF then the DO concentration will jump to values higher than the maximum DO concentration in water which is defined based on Henry's constant.
The slope of the concentration profile gives the mass transfer coefficient and as you can see it is different with 2 URFs. Fluen also gives mas transfer rate ( which varies over time due to the change in O2 concentration in liquid).
