Ali Bachar
in the trm, it seems to have executed fine, showing {inlet} after the command is run. however when plotting a velocity magnitude contour, after loading the journal file, produces a different result then when loading it in the console. it also shows 0 when you click boundary conditions - inlet after loading in the journal
