Lee Chang Hun
I changed the inlet velocity to 25m/s and the solution method from simple to coupled in the initial settings. I did not change any other settings, but I achieved the desired drag coefficient to some extent. Does the initial velocity and method affect the results? Also, there is a suggestion to set the length in the reference value as 1m instead of the car's actual length of 4.3m. Why is that recommended?
