May 5, 2023 at 8:52 am
What does the velocity GUI panel look like before & after running the journal line? It's always wise testing journals on smaller models to check the syntax. Additionally, the TUI string will vary depending on what models are set, and what options are used; they can also change when run a second time as "something" has been set that requires an extra y/n in the command. It's one of the reasons PyFluent is being developed as that should mean you can interact with specific values only without needing to worry about the rest of the boundary settings.
