How many parcels are you tracking (read the TUI reports)? With 300 diameters do you have enough parcels to actually give a curve? Depending on what you're doing it's often better to set 3-5 injections each with a single diameter as you can easily visualise where each size is going. RR has it's uses, but it's not an option we use frequently.
