May 5, 2023 at 11:37 am
So when using 22.1 on the HPC with the above journal file (with the insertion of the ‘()’, this is the output, it seems as if everything executes, but the values say otherwise with the insertion of the brackets I get an even worse output!!
This is with () running on HPC ^
This is original journal file running on HPC ^
This is the expected results, which occurs when you Ctrl + A, Ctrl + C, Ctrl + V the exact journal file into the TUI locally ^
Auto-Transcript Start Time: 12:21:48, 05 May 2023
Current Directory: “/scratch/s381963″
/apps/software/ANSYS/2022R1/v221/fluent/fluent22.1.0/bin/fluent -r22.1.0 3ddp -pinfiniband -host -t64 -mpi=intel -cnf=/var/spool/pbs/aux/243792.crescentpbs -path/apps/software/ANSYS/2022R1/v221/fluent -ssh -cx ccn011.cluster:44585:34804
Starting /apps/software/ANSYS/2022R1/v221/fluent/fluent22.1.0/lnamd64/3ddp_host/fluent.22.1.0 host -cx ccn011.cluster:44585:34804 “(list (rpsetvar (QUOTE parallel/function) “fluent 3ddp -flux -node -r22.1.0 -t64 -pinfiniband -mpi=intel -cnf=/var/spool/pbs/aux/243792.crescentpbs -ssh”) (rpsetvar (QUOTE parallel/rhost) “”) (rpsetvar (QUOTE parallel/ruser) “”) (rpsetvar (QUOTE parallel/nprocs_string) “64”) (rpsetvar (QUOTE parallel/auto-spawn?) #t) (rpsetvar (QUOTE parallel/trace-level) 0) (rpsetvar (QUOTE parallel/remote-shell) 1) (rpsetvar (QUOTE parallel/path) “/apps/software/ANSYS/2022R1/v221/fluent”) (rpsetvar (QUOTE parallel/hostsfile) “/var/spool/pbs/aux/243792.crescentpbs”) (rpsetvar (QUOTE gpuapp/devices) “”))”
Welcome to ANSYS Fluent 2022 R1
Copyright 1987-2022 ANSYS, Inc. All Rights Reserved.
Unauthorized use, distribution or duplication is prohibited.
This product is subject to U.S. laws governing export and re-export.
For full Legal Notice, see documentation.
Build Time: Nov 29 2021 12:13:18 EST Build Id: 10213
Connected License Server List: 1055@cclic-2
This is an academic version of ANSYS FLUENT. Usage of this product
license is limited to the terms and conditions specified in your ANSYS
license form, additional terms section.
Host spawning Node 0 on machine “ccn011.cluster” (unix).
/apps/software/ANSYS/2022R1/v221/fluent/fluent22.1.0/bin/fluent -r22.1.0 3ddp -flux -node -t64 -pinfiniband -mpi=intel -cnf=/var/spool/pbs/aux/243792.crescentpbs -ssh -mport 10.0.1.11:10.0.1.11:37950:0
Starting /apps/software/ANSYS/2022R1/v221/fluent/fluent22.1.0/multiport/mpi/lnamd64/intel/bin/mpirun -f /tmp/fluent-appfile.s381963.80608 –rsh=ssh -genv I_MPI_FABRICS shm:dapl -genv I_MPI_DAPL_UD enable -genv I_MPI_FALLBACK_DEVICE disable -genv FLUENT_ARCH lnamd64 -genv I_MPI_DEBUG 0 -genv I_MPI_ADJUST_REDUCE 2 -genv I_MPI_ADJUST_ALLREDUCE 2 -genv I_MPI_ADJUST_BCAST 8 -genv I_MPI_ADJUST_BARRIER 2 -genv I_MPI_ADJUST_ALLGATHER 2 -genv I_MPI_ADJUST_GATHER 2 -genv I_MPI_ADJUST_ALLTOALL 1 -genv I_MPI_ADJUST_SCATTER 2 -genv I_MPI_ADJUST_SCATTERV 2 -genv I_MPI_ADJUST_ALLGATHERV 2 -genv I_MPI_ADJUST_GATHERV 2 -genv I_MPI_PLATFORM auto -genv I_MPI_DAPL_SCALABLE_PROGRESS 1 -genv PYTHONHOME /apps/software/ANSYS/2022R1/v221/fluent/fluent22.1.0/../../commonfiles/CPython/3_7/linx64/Release/python -genv FLUENT_PROD_DIR /apps/software/ANSYS/2022R1/v221/fluent/fluent22.1.0 -genv FLUENT_AFFINITY 0 -genv I_MPI_PIN enable -genv KMP_AFFINITY disabled -genv LD_PRELOAD /apps/software/ANSYS/2022R1/v221/fluent/fluent22.1.0/multiport/mpi/lnamd64/intel/lib/libstrtok.so -genv TMI_CONFIG /apps/software/ANSYS/2022R1/v221/fluent/fluent22.1.0/multiport/mpi/lnamd64/intel/etc/tmi.conf -machinefile /tmp/fluent-appfile.s381963.80608 -np 64 /apps/software/ANSYS/2022R1/v221/fluent/fluent22.1.0/lnamd64/3ddp_node/fluent_mpi.22.1.0 node -mpiw intel -pic infiniband -mport 10.0.1.11:10.0.1.11:37950:0
ID Hostname Core O.S. PID Vendor
n48-63 ccn014.cluster 16/16 Linux-64 39557-39572 Intel(R) Xeon(R) E5-2660 0
n32-47 ccn012.cluster 16/16 Linux-64 115260-115275 Intel(R) Xeon(R) E5-2660 0
n16-31 ccn013.cluster 16/16 Linux-64 89482-89497 Intel(R) Xeon(R) E5-2660 0
n0-15 ccn011.cluster 16/16 Linux-64 82260-82275 Intel(R) Xeon(R) E5-2660 0
host ccn011.cluster Linux-64 80412 Intel(R) Xeon(R) E5-2660 0
MPI Option Selected: intel
Selected system interconnect: InfiniBand
Cleanup script file is /scratch/s381963/cleanup-fluent-ccn011.cluster-80412.sh
Posting ANSYS Product Improvement Program startup data
Done.
> /file/set-tui-version “22.1”
> /file/read-case “w02-559976.msh”
Reading “w02-559976.msh”…
Buffering for file scan…
103882 nodes, binary.
6722 nodes, binary.
1133582 mixed interior faces, zone 1, binary.
537 triangular velocity-inlet faces, zone 5, binary.
713 triangular pressure-outlet faces, zone 6, binary.
3878 mixed symmetry faces, zone 7, binary.
8097 triangular wall faces, zone 8, binary.
559976 mixed cells, zone 2, binary.
Building…
mesh
auto partitioning mesh by Metis (fast),
distributing mesh
parts…………………………………………..,
faces…………………………………………..,
nodes…………………………………………..,
cells…………………………………………..,
inter-node communication reduction using architecture-aware remapping: 59%
bandwidth reduction using Reverse Cuthill-McKee: 8892/462 = 19.2468
materials,
interface,
domains,
zones,
wall
symmetry
outlet
inlet
fluiddomain
interior-fluiddomain
parallel,
Done.
> /define/models/energy? y n n n y
> /define/models/viscous/kw-sst? y
> /define/materials/change-create air air air is a fluid
y
Density
incompressible-ideal-gas no data required.
n n n n n n
> /define/operating-conditions/operating-pressure 86884.9682
> /define/boundary-conditions/set/pressure-outlet outlet () t0 n 275.65 quit
> /define/boundary-conditions/velocity-inlet (inlet)
inlet ()Please answer y[es] or n[o].
y y n 113.17 n 0 y n 0.99993 n 0.0122 n 0 n 275.65 n n y 5 10
> /solve/monitors/residual/plot? n
> /solve/monitors/residual/convergence-criteria 0.001 0.001 0.001 0.001 0.001 0.001 0.001
> /solve/initialize/compute-defaults/velocity-inlet (inlet)
inlet
> /solve/initialize/initialize-flow
> /solve/iterate 10
iter continuity x-velocity y-velocity z-velocity energy k omega time/iter
1 1.0000e+00 2.1661e-08 2.6245e-09 8.4171e-10 9.4372e-17 9.8517e-01 4.9594e-01 0:00:04 9
Reversed flow on 92 faces (12.8% area) of pressure-outlet 6.
Stabilizing pressure coupled to enhance linear solver robustness.
2 1.0000e+00 7.8196e-07 6.0298e-07 1.6989e-05 1.3736e-16 9.7570e-01 4.9342e-01 0:00:06 8
Reversed flow on 402 faces (50.5% area) of pressure-outlet 6.
3 1.0000e+00 3.6056e-05 2.2458e-04 8.3966e-05 1.4572e-16 9.5851e-01 4.8956e-01 0:00:04 7
Reversed flow on 287 faces (30.1% area) of pressure-outlet 6.
4 1.0000e+00 2.8666e-05 5.3652e-05 3.8766e-05 1.5503e-16 9.2614e-01 4.8324e-01 0:00:03 6
Reversed flow on 265 faces (33.8% area) of pressure-outlet 6.
5 6.3999e-01 6.5669e-05 2.5260e-04 7.7242e-05 2.1236e-16 1.1216e+00 4.7279e-01 0:00:03 5
Reversed flow on 250 faces (31.3% area) of pressure-outlet 6.
6 7.8490e-01 4.5025e-05 7.4854e-05 4.8660e-05 1.1593e-15 8.3821e-01 4.5557e-01 0:00:02 4
Reversed flow on 216 faces (25.3% area) of pressure-outlet 6.
7 6.3548e-01 4.1996e-05 1.1698e-04 5.1480e-05 2.3377e-15 7.7233e-01 4.2520e-01 0:00:01 3
Reversed flow on 244 faces (30.3% area) of pressure-outlet 6.
8 6.7845e-01 3.9463e-05 5.0019e-05 3.5548e-05 1.1140e-14 1.3640e+00 3.8517e-01 0:00:01 2
Reversed flow on 219 faces (26.7% area) of pressure-outlet 6.
9 5.4719e-01 3.5438e-05 6.0341e-05 3.5188e-05 6.7081e-13 5.6467e-01 3.1867e-01 0:00:00 1
Reversed flow on 212 faces (26.9% area) of pressure-outlet 6.
10 4.9685e-01 3.1213e-05 3.2773e-05 2.6411e-05 6.1261e-13 4.8691e-01 2.5416e-01 0:00:00 0
> /file/write-data “testing.dat.h5″Fast-loading “/apps/software/ANSYS/2022R1/v221/fluent/fluent22.1.0/addons/afd/lib/hdfio.bin”
Done.
Writing to ccn011.cluster:”/scratch/s381963/testing.dat.h5” in NODE0 mode and compression level 1 …
Writing results.
Done.
> /exit
Posting ANSYS Product Improvement Program performance data
Done.
ok Auto-Transcript Stop Time: 12:27:15, 05 May 2023
Total Transcript Time: 5 Minute 26 Second.
