In the Rocky-Fluent coupling, the fluid flow is obtained by the conventional continuum approach using Ansys Fluent.
The coupling between solid and fluid is accomplished by interphase momentum and heat transfer
terms due to the interaction between phases.
You can add forces in the phase interaction panel in the multiphase model.
Thank you.
