You're initializing velocity by part ID? By node set?
I suspect your constraints (SPCs, etc) may be incorrect and therefore restricting movement of the material.
Files cannot be shared via this Forum. You can file a Service Request via the Ansys Customer Portal if you are a commercial customer.
