I thought this post was replied however it seems the reply is gone to the wind.
I believe your result is reasonable: in 2D simulation by default we assume the 3rd dimension "norm length" is 1cm thick, if you did not change it. However in 3D I think you may not use 1cm thickness. The RC will be very different in the two cases.
