Praneeth
Thank you for reaching out to the Ansys Learning Forum. Your patience is much appreciated.
It is good to hear that you were able to solve your issue by following the Ansys How To videos.
If it helps you can also go through "Link from Driven Modal or Terminal Antenna to SBR+ Design" section of the HFSS help pdf document and "Dish FEBI IE PO" example project to learn more details about the linked field.
Alternatively, you can also go through these links -Ansys Electronics 2023 R1 - Assigning Excitations for HFSS or HFSS-Transient and Ansys Electronics 2023 R1 - Other HFSS Examples with Descriptions in the Help to acsess these topics.
Best regards,
Praneeth.
Forum Rules & Guidelines - Innovation Space (ansys.com)
