I don't need to see the second STL.
Yes, you can use the skin method to cut a wing from a solid block instead of cutting air from a solid block.
If you are cutting the wing, there is no difficulty at the trailing edge. Since I don't use ICEM, I don't know if that will be difficult or easy.
Good luck.
