May 6, 2023 at 5:33 pm
Thank you for reaching out to the Ansys Learning Forum. Your patience is much appreciated.
Were you able to solve your issue?
If not, please go through the following instructions:
- Add the 6th face of the cavity at the required place in the simulation from where you want to link the field.
- Run the simulation with save fields option selected.
- After the simulation is complete, copy and paste the face at the required place and assign linked field excitation.
- Simulate the model and plot the results.
For setting up linked field, please go through "Link from Driven Modal or Terminal Antenna to SBR+ Design" section of the HFSS help pdf document and "Dish FEBI IE PO" example project to learn more details about the linked field.
Alternatively, you can also go through these links -Ansys Electronics 2023 R1 - Assigning Excitations for HFSS or HFSS-Transient and Ansys Electronics 2023 R1 - Other HFSS Examples with Descriptions in the Help to acsess these topics.
Best regards,
Praneeth.
Forum Rules & Guidelines - Innovation Space (ansys.com)
