May 8, 2023 at 7:34 am
Hello Ashish,
My model involves material plasticity and contact pairs. It failed at the 4th step.
#The 2nd step involves many warnings like below. Any actions needed?
*** WARNING *** CP = 1035.703 TIME= 12:46:21
The current Level of Difficulty on the PCGOPT command may be inefficient for this model due to coupling equation(s) and/or constraint equation(s) present. If this solution appears to be inefficient, you may find that switching to a Level of Difficulty equal to 1 [PCGOPT,1] more efficient for this model.
#The 3rd step involve warnings, notes, and errors like below. Any actions needed ?
*** WARNING *** CP = 38533.234 TIME= 23:15:25
FORCE CONVERGENCE VALUE = 0.5708E+05 CRITERION= 2632.
MOMENT CONVERGENCE VALUE = 28.08 CRITERION= 0.5102E-04
*** NOTE *** CP = 38790.953 TIME= 23:19:43
The preconditioned conjugate gradient solver failed to converge, and therefore no solution was obtained. The equation solver is now being automatically switched to the sparse solver (EQSLV,SPARSE) to allow this analysis to continue.
DISP CONVERGENCE VALUE = 0.4709 CRITERION= 0.1124
EQUIL ITER 1 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.4709
DISP CONVERGENCE VALUE = 0.1518 CRITERION= 0.1147
LINE SEARCH PARAMETER = 0.3224 SCALED MAX DOF INC = -0.1518
FORCE CONVERGENCE VALUE = 0.3857E+05 CRITERION= 171.9
MOMENT CONVERGENCE VALUE = 23.37 CRITERION= 248.1 <<< CONVERGED
EQUIL ITER 2 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.7681E-01
DISP CONVERGENCE VALUE = 0.7563E-01 CRITERION= 0.1171 <<< CONVERGED
LINE SEARCH PARAMETER = 0.9847 SCALED MAX DOF INC = 0.7563E-01
FORCE CONVERGENCE VALUE = 1965. CRITERION= 175.3
MOMENT CONVERGENCE VALUE = 2.255 CRITERION= 253.0 <<< CONVERGED
EQUIL ITER 3 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.9337E-02
DISP CONVERGENCE VALUE = 0.9337E-02 CRITERION= 0.1194 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.9337E-02
FORCE CONVERGENCE VALUE = 401.8 CRITERION= 179.3
MOMENT CONVERGENCE VALUE = 0.5137E-01 CRITERION= 258.7 <<< CONVERGED
EQUIL ITER 4 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.6605E-02
DISP CONVERGENCE VALUE = 0.6605E-02 CRITERION= 0.1219 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.6605E-02
FORCE CONVERGENCE VALUE = 198.5 CRITERION= 183.0
MOMENT CONVERGENCE VALUE = 0.5709E-01 CRITERION= 264.1 <<< CONVERGED
EQUIL ITER 5 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.6990E-02
DISP CONVERGENCE VALUE = 0.6990E-02 CRITERION= 0.1244 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = -0.6990E-02
FORCE CONVERGENCE VALUE = 210.0 CRITERION= 187.0
MOMENT CONVERGENCE VALUE = 0.3405E-01 CRITERION= 270.0 <<< CONVERGED
EQUIL ITER 6 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.7422E-02
DISP CONVERGENCE VALUE = 0.7422E-02 CRITERION= 0.1269 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = -0.7422E-02
FORCE CONVERGENCE VALUE = 142.2 CRITERION= 191.0 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.1315E-01 CRITERION= 275.6 <<< CONVERGED
>>> SOLUTION CONVERGED AFTER EQUILIBRIUM ITERATION 6
*** LOAD STEP 3 SUBSTEP 4 COMPLETED. CUM ITER = 109
*** TIME = 2.40000 TIME INC = 0.100000
*** MAX PLASTIC STRAIN STEP = 0.1679E-02 CRITERION = 0.1500
*** AUTO TIME STEP: NEXT TIME INC = 0.15000 INCREASED (FACTOR = 1.5000)
*** NOTE *** CP = 43066.172 TIME= 00:30:59
The equation solver is automatically reverting from the sparse solver back to the preconditioned conjugate gradient solver.
*** ERROR *** CP = 46802.359 TIME= 01:33:17
Element 73021 (type = 2, SOLID187) (and maybe other elements) has become highly distorted. Excessive distortion of elements is usually a symptom indicating the need for corrective action elsewhere. Try incrementing the load more slowly (increase the number of substeps or decrease the time step size). You may need to improve your mesh to obtain elements with better aspect ratios. Also consider the behavior of materials, contact pairs, and/or constraint equations. Please rule out other root causes of this failure before attempting rezoning or nonlinear adaptive solutions. If this message appears in the first iteration of first substep, be sure to perform element shape checking.
*** NOTE *** CP = 201257.641 TIME= 20:30:35
The incremental plastic strain 62.2106268% computed in this iteration is larger than the criterion of 15% leading to bisection. You may try incrementing the load more slowly by increasing the number of substeps or use the CUTCONTROL command to re-specify this criterion.
#The solution stopped at load step 4, substep 16 with error as shown below. How can I correct the errors?
>>> SOLUTION CONVERGED AFTER EQUILIBRIUM ITERATION 7
*** LOAD STEP 4 SUBSTEP 15 COMPLETED. CUM ITER = 416
*** TIME = 3.41150 TIME INC = 0.100000E-01
*** MAX PLASTIC STRAIN STEP = 0.3756 CRITERION = 0.1500
*** AUTO STEP TIME: NEXT TIME INC = 0.10000E-01 UNCHANGED
FORCE CONVERGENCE VALUE = 2963. CRITERION= 277.2
MOMENT CONVERGENCE VALUE = 0.4922 CRITERION= 0.5102E-04
DISP CONVERGENCE VALUE = 0.5154E-01 CRITERION= 0.1124 <<< CONVERGED
EQUIL ITER 1 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.5154E-01
DISP CONVERGENCE VALUE = 0.2969E-01 CRITERION= 0.1147 <<< CONVERGED
LINE SEARCH PARAMETER = 0.5760 SCALED MAX DOF INC = -0.2969E-01
FORCE CONVERGENCE VALUE = 1259. CRITERION= 136.2
MOMENT CONVERGENCE VALUE = 0.2087 CRITERION= 196.5 <<< CONVERGED
EQUIL ITER 2 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.2179
DISP CONVERGENCE VALUE = 0.1155E-01 CRITERION= 0.1171 <<< CONVERGED
LINE SEARCH PARAMETER = 0.5303E-01 SCALED MAX DOF INC = 0.1155E-01
FORCE CONVERGENCE VALUE = 1190. CRITERION= 138.9
MOMENT CONVERGENCE VALUE = 0.1977 CRITERION= 200.5 <<< CONVERGED
EQUIL ITER 3 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1992
DISP CONVERGENCE VALUE = 0.1992 CRITERION= 0.1194
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.1992
FORCE CONVERGENCE VALUE = 7999. CRITERION= 141.7
MOMENT CONVERGENCE VALUE = 0.8859E-02 CRITERION= 204.6 <<< CONVERGED
EQUIL ITER 4 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.3821E-01
DISP CONVERGENCE VALUE = 0.3821E-01 CRITERION= 0.1219 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = -0.3821E-01
FORCE CONVERGENCE VALUE = 4421. CRITERION= 144.7
MOMENT CONVERGENCE VALUE = 0.9883E-02 CRITERION= 208.8 <<< CONVERGED
EQUIL ITER 5 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.1681
DISP CONVERGENCE VALUE = 0.6666E-01 CRITERION= 0.1244 <<< CONVERGED
LINE SEARCH PARAMETER = 0.3966 SCALED MAX DOF INC = -0.6666E-01
FORCE CONVERGENCE VALUE = 3094. CRITERION= 147.6
MOMENT CONVERGENCE VALUE = 0.6133E-02 CRITERION= 213.1 <<< CONVERGED
EQUIL ITER 6 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.3314
*** ERROR *** CP = 248350.578 TIME= 09:35:44
Element 1293421 (type = 5, SOLID187) (and maybe other elements) has become highly distorted. Excessive distortion of elements is usually a symptom indicating the need for corrective action elsewhere. Try incrementing the load more slowly (increase the number of substeps or decrease the time step size). You may need to improve your mesh to obtain elements with better aspect ratios. Also consider the behavior of materials, contact pairs, and/or constraint equations. Please rule out other root causes of this failure before attempting rezoning or nonlinear adaptive solutions. If this message appears in the first iteration of first substep, be sure to perform element shape checking.
*** WARNING *** CP = 248350.781 TIME= 09:35:45
The unconverged solution (identified as time 4 substep 999999) is output for analysis debug purposes. Results should not be used for any other purpose.
Although the solution has many element distortions, they might not be the root cause. May increasing the Maximum substeps from 100 to 200 help solve the errors?
Thank you,
Colin
