Aniket
student versions do not support CAD connections. Assuming that you have research or commercial license which can support this, try the following all with administrative access:
  1. Close all workbench and CAD instances
  2. Unconfigure for all users reader mode, you may also unconfigure for the current user after that
  3. unconfigure for all users associative mode, you may also unconfigure for the current user after that
  4. now check Windows (ansys.com) (https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v202/en/ref_cad/cadWindows.html) for supported versions of the CAD in Plugin mode and check if you are using a supported version of the CAD
  5. now configure in associative mode and start new session of CAD and see if you can see a separate menu for starting the workbench in the CAD, if you see that, the configuration is successful in the associative mode
  6. Now create a simple cube, and save the CAD file and then start workbench from CAD, keep prefixes as blank, and open the geometry in Mechanical. This should read all parameters.
-Aniket
