Chandra Sekaran
I would recommend running one case with small mesh size (like say 5 mm) without using parameter updates i.e. just solve in Mechanical with 5 mm size. Then review the results and make sure this parameter has the intended effect on the results. This is to see if the issue is with the parameterized quantity.
