I am facing an issue with parametrizing distances between two components in my imported geometry. Specifically, I have a polymer component (component 1) with a metal inlay component (component 2) inside it, and I am trying to import this geometry into my software. However, I am unable to parametrize the distances between the two components, and I need some guidance on how to achieve this. Can you please help me with this issue?
I attempted to use the solution you provided by going through SpaceClaim, selecting "Pull", and then parametrizing the distances between the two components. However, this method did not work for me, and I am still unable to successfully parametrize the distances between component 1 and component 2. Can you suggest any other methods or provide further guidance on how to accomplish this task?
