try comparing solver outputs side by side. Try to eliminate as many differences in the model and see if you still get drastically different results. To verify, save your solved model in 2022R1, and open the same in 2022R2, and rerun it without clearing the mesh. And then check the difference in results. Also do mesh convergence study.
-Aniket
