Aniket
Ansys staff can not download any files on the forum, so if you want to reach a larger audience to get answers from, please insert inline images describing your problem.
Are you seeing the difference in Maxwell or Transient thermal?
Also, are you sure that you are running exact same file in the same version? if you copy and run the model with the same BCs you should ideally see the same results.
-Aniket
