Sahil Sura
Hi chiheb ben abdallah,
If the computational limitation is present, you can go for Linear elements (single order), as the default mesh uses second-order elements. This will help you see a change in the solution time as a relatively less number of equations will be formed for the solver to compute.
Mesh (ansys.com)
You can also go for mesh sizing options, to mesh the critical areas with relatively fine mesh.
Specifying an Appropriate Element Size for Stress Analysis — Lesson 1 - ANSYS Innovation Courses
You can also try solving the model using symmetry if the boundary conditions suit for the some cases.
Understanding when to Take Advantage of Symmetry - Lesson 3 - ANSYS Innovation Courses
Also, you can find the latest version of Ansys Student from the following link- Ansys Student Versions | Free Student Software Downloads
Hope this helps!
Thanks,
Sahil
https://forum.ansys.com/forums/topic/how-to-access-the-ansys-online-help/
https://forum.ansys.com/forums/topic/guidelines-for-posting-on-ansys-learning-forum/#latest
