May 10, 2023 at 4:53 pm
@Youngin Kim,
From your command, it seems that you are running a script that calls the FDTD GUI/CAD. Please check with IT or the person who created the script/executable "lumerical fdtd-solutions" to check what is called by this script/executable.
Typically we run the CAD (using the default install path for 2022 R1.1)
/opt/lumerical/v221/bin/fdtd-solutions
or in your case try opening the FDTD CAD?GUI directly from terminal. Do not use "lumerical fdtd-solutions"
/usr/pack/lumerical-2022_r1.1-bt/bin/fdtd-solutions
From your screenshot it shows "Segmentation fault error" -- there is something wrong with your installation. It's could be missing system or graphics libraries needed by the CAD/GUI see this Knowledge Base (KB) for details.
