Praneeth
Thanks for sharing the HPC options. I have only one observation about the cores, the rest is fine. Please check the available core quantity in your machine, modify the cores quantity accordingly in the analysis configuration window and try simulating the model once again. During the simulation monitor the RAM usage. If the simulation does not succeed then observe the stage of the analysis during which you receive the error message.
Please share the solution setup screenshot if possible to see if any suggestions can be offered.
Best regards,
Praneeth.
