Hi Peter,
I would like to ask if it is possible to create a mesh with the same number of elements across the thickness of the wall. This would have to increment the element size in accordance to the thickness of the wall which varies in the z axis. Also is it possible to eliminate the piramids and force only hex elements.
In attachment i have an image of the mesh i am trying to build.
Thank you.
