May 12, 2023 at 9:09 am
Thanks for your help.I'll answer your questions point by point :
- My adiabatic efficiency varies from 2.25 % when compared to CFX. I'll upload the report below.
- I am using the 2022 R2 version of ANSYS Fluent
- The residuals did converged to my absolute criteria of 10e-5 in 407 interations. My reports ( pressure ratio, temperature ratio, mass flow rate and efficiency) are balanced as well as the mass imbalance.
- Here are my velocity contours, static temperature contours, static pressure contours and relative veloctity vectors at various spans to give you an idea.
If you need futher information or any other results don't hesitate to ask me.
Velocity :
Temperature :
Pressure :
Adiabatic efficiency report :
