Alexandre Gomes
I was using the Hex dominant Method because I checked and only 3 out of 15 bodies are sweepable. In the sweepable bodies this works really well, however when i attempt to sweep the others, the mesher fails to initiate.
In attachment there is an image of my geometry with the sweepable bodies highlighted, is there a way to make the others sweepable?
Thank you very much for your help!
