Akshay Maniyar
Hi Abhijeet,
For more details about the warning message, you can refer to the below link.
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v231/en/wb_sim/ds_Large_Deformation_Effects.html?q=large%20deformation%20effects%20are%20active
As per the deformation plots, it looks like the penetration is because of the scale factor which you have used. You can change it to 'True scale' and then check if it looks correct or not.
Thank you,
Akshay Maniyar
