May 14, 2023 at 7:24 am
hello
i performed a static analysis on the semi-trailer and i want to perform a dynamic analysis using the results of the static analysis to simulate its interaction with the road should i share the results with the model or with the setup?
i also want to determine the stresses, the displacements, and the frequencies which type(s) of dynamic analysis should i use?
