Alejandro Ruiz
I have introduced the experimental data of tensile and
compression as you have indicated but the re
sults of tensile and compression are not the same.
Please find attached pictures for further clarification. I can't find an explanation why with the same conditions the tensile test is ok but the compression test is not. I have been thinking and testing for a long time but I can't find the answer.
Thank you very much for your support.
