If you are using solid185 for the bolt then it must be an actual geometric body which you could make a named selection for. Then the line esel,s,enam,,188 could be replaced by cmsel,s,name where "name" is the name you give the named selection. SENE is just structural strain energy, 1/2 int(stress*strain)dv
