The solution result is in the data file (.dat.gz or .dat.h5 depending on version and/or preferences). If you look in the Fluent Parallel tab there are system metrics available.
CPU usage should show up in the Task Manager. However, it's not always simple if you're writing files and/or low on RAM.
