Hi Greg,
Checking/unchecking features in SpaceClaim will not make any difference to the geometry that is imported into Aqwa Workbench. Aqwa will only use the Surface Bodies and Beams (with their associated Beam Profiles) that are defined in the model, as long as they are active, i.e. not Suppressed for Physics. It will ignore everything else (sketches, planes, points, construction geometry etc).
Cheers, Mike
