OK. If the temperature in the fluid domain is below saturation temperature you’ve potentially got a problem: read up on the VOF model and how it works.
It’s too early, I need more tea. Positive mass flow is into the domain. But you should hit zero when the film is in equilibrium with the surroundings.
