Chandra Sekaran
Not sure why you are first selecting the nodes with VOLT value? You have not applied it yet. I think the "nsel,s,d,volt" is returning zero nodes and so when you do "nsel,r,loc,z,0" you are getting nothing. I would remove the "nsel,s,d,volt" command and just do "nsel,s,loc,z,0"
Also you can do a DLIST to make sure the voltage bc is applied.
NSEL,S,D,VOLT
NSEL,R,LOC,Z,0
CM,bottom_elec,NODE
CP,2,VOLT,ALL
*GET,N2,NODE,,NUM,MIN
ALLSEL
D,bottom_elec,VOLT,0
