May 16, 2023 at 2:05 am
Hello Rob
Thank you for agreeing to help me
Attached below is a photo of the injection panel. I can't figure out how to set solid cone spraying. As I understand it, the speed in x,y,z allows you to set only one velocity vector, and not a set of vectors.
I will also add the information that I am modeling the spraying of solid microparticles from the inlet, a stream of CO2 also comes out of the inlet. I use Fluid Flow (Fluent). (perhaps in this software package it is impossible to set the shape of a solid particle spray torch and you need to use another package?)
