Hi
If the model has solved and want to check where that remote point is, just create a result and scope it to that node (say node 759781 in your case).
To scope a result to a node (974 in this case) see here:
You would need to replace and add the node number of interest in the Solver Comp. Ids.
Thank you
Erik
