Erik Kostson
Hi
The issue is that the acceleration needed here to activate the sloshing formulation is also applied (structural load) to all the structural bodies (so this will always be a problem so you can not do what you are trying to do).
If you just need the sloshing frequencies and modes, just use a modal acoustic analysis with acceleration and free surface.
All the best
Erik
