Hello Rob,
the Simulation I was asking about earlier started working, now I am on to the next iteration and I get the following error, do you know how I can fix it, or at leat tell me where to look. I am new to this, and I am trying as hard as possible to learn! Thanks in advance.
*** Starting Step 1 ***
Parameters and Fields | Progress bar(s) |
Evolution parameter S = 7.5500000E-01 |> |
Parameter fac = 5.4328477E+04 |> |
Parameter expom = 1.0000000E+00 |> |
Preprocessors
Convergence assumed : Rel. var. LT 1.00000E-03
F.E.M. Task
Divergence detected for field VELOCITIES: iterations cancelled by Expert System
Divergence of influent solver occurred !
*** WARNING *** from [EVOLUT]
First step does not converge
It is not possible to start the evolution scheme
* Summary of the simulation *
The computation failed.
* Expert tool diagnostics *
The problem F.E.M. Task has not converged.
This is the Error message I get in the Listing viewer. I don't really understand why it has a problem with the evolution parameters. I got a failure earlier and I set them to exactly what the Expert System recommended...
Julen
