Hello Jose,
In report dialog, you could find pull-down menu of solution in right top corner, and select “Setup1:AdaptivePass” (possible), then you can plot selected quantity vs. pass.
When you change “Percent Error” for calculation tolerance, you will get different results. Small percent error could get more accurate results and you can consider force as convergence item in Expression Cache. Please review the help manual.
Howard
